#83235 by Tim Mohr
Thu Oct 10, 2024 4:27 pm
I am getting ready to pull the plug on this program if it can't do a better job of printing multipage files...it is driving me nuts. I do use a lot of x-refs but am careful with nesting and nothing is absurdly big but it is ridiculously slow and very fussy. Anyone else have similar issues? I don't recall having this kind of issue in years gone by - otherwise I would have bailed long ago. I have a ton of stuff due and the best I can manage at the moment is screen shots....
#83237 by Tim Mohr
Thu Oct 10, 2024 8:01 pm
Hi Mark -
I apparently have 23.00.02.21 - which according to the update dropdown is the latest and greatest - do I need to download this directly as it's not recognized by the update script? Sorry to sound irritated, but I have wasted a ton of time trying to get this to print consistently and it has been a bear. Among other things, pak-n-go is crashing at the same rate as batch/pdf printing so really boxed into a corner at this point and I have an owner as well as the owner's agent breathing down my neck :) and questioning my competence - not a good look. Will go grab the update and see if that will allow me to assemble a pak-n-go....thanks for getting back to me.
Tim
#83239 by Clayton Taylor
Fri Oct 11, 2024 6:48 am
Mark F. Madura wrote:Hi Tim,
Did you update to 23.00.03.03? Can you PAK up or ZIP up the files for the project and send them to [email protected] so I can test it here.
Thank You,
MFM
Now I'm confused.... :? :?
I thought DC 23.00.03.03 was still being tested as a release candidate, my version of DC from the pull down Help menu states Version: 23.00.02.21 (PE) & also states on the check for updates that this is the latest version.
I've been switching between DC ver.18 & 23 on some projects, mainly the ones where I've started on DC18 & typically found DC ver.23 to be slower, e.g. a manual save for instance. I also had an issue with hatching/fills on one project with DC ver.23 that kept crashing, so had to revert back to DC18 to complete the project.
#83241 by MtnArch
Fri Oct 11, 2024 10:20 am
Mark posted this update (I believe) to the general V23 forum - you should be able to download it and install it.
